Date/Time: Sun, 19 Jan 2025 19:52:33 +0000
need RT symbol but it is 1 day delayed
View Count: 807
[2018-05-02 01:45:41] |
Willson - Posts: 176 |
using Gain capital. trying to incorporate FDAXM8 real time, I only get it delayed. Do i need to talk to Gain cap or does this get furnished by SC feed? Any suggestions?
[2018-05-02 02:33:06] |
You should contact Gain Capital for real-time data for the EUREX.
