Date/Time: Sun, 19 Jan 2025 17:47:01 +0000
stochastic and MACD divergence signals or alert
View Count: 931
[2018-05-01 16:29:38] |
User78439 - Posts: 22 |
There are built-in signals or alerts for Stochastic and MACD divergence ? Thanks.
[2018-05-01 18:45:30] |
No. You need to create your own Alerts to meet your requirements. Refer to this page: http://www.sierrachart.com/index.php?page=doc/StudyChartAlertsAndScanning.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
