Date/Time: Sun, 19 Jan 2025 19:38:03 +0000
Study Summary Sheet
View Count: 800
[2018-05-01 15:28:31] |
User28682 - Posts: 233 |
I have alerts coming into a Study Summary Sheet. Is there a way to have the Study Summary Sheet update only when the bars close? and not intrabar? Or can I make the individual alert from a chart update on a bar closing only? Thanks |
[2018-05-01 17:52:53] |
The option you want is to have the alert only occur on the Bar close. You will find the documentation for this here: Study/Chart Alerts And Scanning: Evaluate on Bar Close Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-05-02 03:18:06] |
Thanks, its not exactly clear cut...so the "Evaluate on Bar Close" is a bar updating and sending an alert only after that bar closes out?
[2018-05-02 19:19:58] |
Would be best to enable the option and you should see that it works as intended.
