Date/Time: Sun, 19 Jan 2025 18:03:08 +0000
Offsetting arrows from bar High/Low
View Count: 1189
[2018-05-01 15:16:06]
User606491 - Posts: 164
On the spreadsheet system for trading and the spreadsheet study, I would like to use "arrow up" and "arrow down" on columns other than K-N.
However, when I do so, the arrows appear on the chart at value = 1. This dramatically skews the chart.
What setting should I change to have up arrows offset from the bar low and down arrows offset from the bar high?
Said differently, I would like the up/down arrows to appear on the chart exactly as they do for columns K-N.
thank you,
[2018-05-01 17:20:37]
Sawtooth - Posts: 4157
Use a formula like this to place the Arrow Up at the low of the bar:
=IF(YourUpFormula,D3,0)
And one like this to place the Arrow Down at the high of the bar:
=IF(YourDownFormula,C3,0)
[2018-05-01 17:49:16]
Can't thank you enough, Tom.
Best,
Eric
[2018-05-01 19:50:58]
This is explained here:
http://www.sierrachart.com/index.php?page=doc/SpreadsheetSystemsAlertsAndAutomatedTrading.php#ControllingTheLocationOfArrowsOrSubgraphValues
