Date/Time: Tue, 26 Nov 2024 02:26:37 +0000
[Programming Help] - How can I add Note in trades in trade activity log?
View Count: 2191
[2018-05-01 14:50:04] |
User378082 - Posts: 33 |
There is a column named Note,but I can not do anything about it. I've searched the help. no find.
[2018-06-28 13:41:43] |
no one can help me. Sorry for bother you. I just mean I want to add some journal in my trade activity logs. tks. |
[2018-06-28 18:35:11] |
This is done through the Text Tag setting on the Trade Window: http://www.sierrachart.com/index.php?page=doc/TradeWindow.html#TextTag Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-07-28 18:10:05] |
TonyCipriani - Posts: 19 |
Hey, Is it possible to use multiple Text Tags in the note column? I'm looking to use this for journaling and I wanted to know what can be done if there were two or more different setups that can be classified for the trade. For instance, if the trade can be tagged as both a Stochastic divergence, and also a News Catalyst. Thanks |
[2023-07-28 19:29:10] |
John - SC Support - Posts: 36286 |
There is only one Note/Text Tag entry. In order to enter two items, you need to enter them together (i.e. you would enter "Stochastic Divergence" for one trade and "Stochastic Divergence | News Catalyst" for another).
[2024-01-09 20:48:48] |
User194332 - Posts: 40 |
Hi John I am using the Trade Activity Log to add notes but was wandering if it is possible to edit multiple fills @ the same time? see attached image. The Edit menu has it greyed out. Regards Avi |
Sierra Note Edit .png / V - Attached On 2024-01-09 20:48:05 UTC - Size: 113.24 KB - 58 views |
[2024-01-09 21:06:02] |
You can not edit multiple fills at the same time. That is why it is greyed out. If you had one selected, you could then select it.
