Date/Time: Sun, 19 Jan 2025 17:56:26 +0000
Simple Price Alert
View Count: 1562
[2018-04-30 17:38:55]
User92573 - Posts: 541
Dear Support
I have been unable to find a simple Price Based Alert that will allow me to select a price-level (Chart Values/ Cross Hair) or individual price bar (OHLC), and simply ask: IF Price is <, >, =, the Price-level THEN Trigger Alert Sound/Message etc.
It's so basic that I'm sure its there somewhere.
Many thanks.
[2018-04-30 18:22:02]
Xfanman1 - Posts: 320
There are 2 ways that I know of that you can do this.
#1 You can set an alert using the Add Symbol Alert menu item and that will allow you to specify an alert that you'll manage via the Window/Alert Manager/Symbol Alert tab.
Alerts Manager: Symbol Alerts
#2 My preferred way is to configure a Horizontal Line Alert, follow the link to see how to set alerts to Chart Drawings.
Chart Drawing Tools: Chart Drawing Alerts
Scott
imagePrice Alert.PNG / V - Attached On 2018-04-30 18:21:46 UTC - Size: 20.36 KB - 274 views
imageHorizontal Line Alert.PNG / V - Attached On 2018-04-30 18:21:58 UTC - Size: 46.26 KB - 271 views
[2018-04-30 18:44:44]
You need to use the Symbol Alert feature:
