Date/Time: Sun, 19 Jan 2025 19:47:30 +0000
FX Indexes don't update
View Count: 843
[2018-04-30 17:06:55] |
User300798 - Posts: 23 |
Hi, I use the SC FX Indexes daily. However, they don't update during the day. When I first look at them in the morning the intraday and historical charts download the latest data and update. When I check back durgin the day, the historical charts don't update and I have to go to Edit>Download data from end of chart to update them. The intraday charts do download the latest data from that day but then do not update in real time. Any help appreciated. Thanks. |
[2018-04-30 18:27:51] |
Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings Also check the Session Times as documented here: http://www.sierrachart.com/index.php?page=doc/helpdetails3.html#StartAndEndTimesNotCoveringCurrentTime If there still is a problem, refer to help topic 3.4 to see if real-time data is being received: Intraday Chart or Chart Bars Not Updating | Blank Intraday Chart | "Currently no data to display" message for Intraday Chart: 3.4 - Not Receiving Real-Time Data From Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-04-30 18:28:32
[2018-05-01 13:31:16] |
Thanks for the links. I've updated the global settings, checked the session times and been through the help topic but still not getting real time data. I'm using the LMAX demo data feed - I assume SC market stats are included with this? Thanks. |
[2018-05-01 19:06:58] |
Tell us the symbol that is not updating and provide a copy of the Message Log following these instructions here: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) I'm using the LMAX demo data feed - I assume SC market stats are included with this? Yes.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-05-01 19:07:28
[2018-05-01 21:10:09] |
Hi, The symbols not updating are all the FX Indices included in SC Market Stats including USDX. Message log below. Thanks Reading Internal Order ID file. | 2018-05-01 22:00:50 Reading Trade Orders file. | 2018-05-01 22:00:50 Reading Trade Positions file. | 2018-05-01 22:00:50 Using Bid/Ask average for last trade price for GDAXI | 2018-05-01 22:00:50 Using Bid/Ask average for last trade price for XBRUSD | 2018-05-01 22:00:50 Using Bid/Ask average for last trade price for J225 | 2018-05-01 22:00:50 Using Bid/Ask average for last trade price for XTIUSD | 2018-05-01 22:00:50 Listening on UDP port 22903. | 2018-05-01 22:00:50 Software version: 1623 | 2018-05-01 22:00:50 Usage end date: 2018-06-09 | 2018-05-01 22:00:50 Enabled for: Advanced Features. | 2018-05-01 22:00:50 Enabled for: Sierra Chart Historical Data Service. | 2018-05-01 22:00:50 Allow Support for Sierra Chart Data Feeds is enabled. | 2018-05-01 22:00:50 Current selected Data/Trading service: LMAX Demo Trading - DTC | 2018-05-01 22:00:50 Chart Update Interval: 500 | 2018-05-01 22:00:50 Time Zone: +01:00:00 (GMT+00BST+01,M3.5.0/01:00,M10.5.0/02:00) | 2018-05-01 22:00:50 2018-05-01 22:00:55 Local computer time | 2018-05-01 22:00:50 2018-05-01 21:00:55 Local computer time in UTC | 2018-05-01 22:00:50 2018-05-01 22:00:55 Local computer time in SC Time Zone | 2018-05-01 22:00:50 2018-05-01 21:00:53 Server time in UTC | 2018-05-01 22:00:50 Local computer UTC time and Server UTC time difference: 1 seconds. | 2018-05-01 22:00:50 Program path: C:\SierraChart\ | 2018-05-01 22:00:50 Data Files path: C:\SierraChart\Data\ | 2018-05-01 22:00:50 OS Version Number: 10.0 | 2018-05-01 22:00:50 Locale Setting: C | 2018-05-01 22:00:50 Created the DTC Protocol server. | 2018-05-01 22:00:50 DTC Protocol Server listening on port 11099. | 2018-05-01 22:00:50 Created the DTC Protocol historical data server. | 2018-05-01 22:00:50 HD Server Manager | Listening on port 11098 | 2018-05-01 22:00:50 Checking for new symbol settings for service code lmax | 2018-05-01 22:00:50 HTTPS connection to www.sierrachart.com:443 (4) | Creating socket. Using TLS 1.2. | 2018-05-01 22:00:50 HTTPS connection to www.sierrachart.com:443 (4) | Connecting to IP: 204.15.192.108. | 2018-05-01 22:00:50 Symbol settings are up-to-date for lmax | 2018-05-01 22:00:50 Received 5 login tokens. | 2018-05-01 22:00:56 HTTPS connection to www.sierrachart.com:443 (5) | Creating socket. Using TLS 1.2. | 2018-05-01 22:00:57 HTTPS connection to www.sierrachart.com:443 (5) | Connecting to IP: 204.15.192.108. | 2018-05-01 22:00:57 HTTPS connection to www.sierrachart.com:443 (4) | Socket gracefully closed by remote side. | 2018-05-01 22:01:00 HTTPS connection to www.sierrachart.com:443 (4) | Received socket Close event. | 2018-05-01 22:01:00 HTTPS connection to www.sierrachart.com:443 (4) | Initiating close of socket by core. | 2018-05-01 22:01:00 HTTPS connection to www.sierrachart.com:443 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-05-01 22:01:00 HTTPS connection to www.sierrachart.com:443 (4) | Closed. | 2018-05-01 22:01:00 HTTPS connection to www.sierrachart.com:443 (2) | Socket gracefully closed by remote side. | 2018-05-01 22:01:01 HTTPS connection to www.sierrachart.com:443 (2) | Received socket Close event. | 2018-05-01 22:01:01 HTTPS connection to www.sierrachart.com:443 (2) | Initiating close of socket by core. | 2018-05-01 22:01:01 HTTPS connection to www.sierrachart.com:443 (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-05-01 22:01:01 HTTPS connection to www.sierrachart.com:443 (2) | Closed. | 2018-05-01 22:01:01 HTTPS connection to www.sierrachart.com:443 (5) | Socket gracefully closed by remote side. | 2018-05-01 22:01:02 HTTPS connection to www.sierrachart.com:443 (5) | Received socket Close event. | 2018-05-01 22:01:02 HTTPS connection to www.sierrachart.com:443 (5) | Initiating close of socket by core. | 2018-05-01 22:01:02 HTTPS connection to www.sierrachart.com:443 (5) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-05-01 22:01:02 HTTPS connection to www.sierrachart.com:443 (5) | Closed. | 2018-05-01 22:01:02 Files to Open on Start up | Opening file: 5.cht | 2018-05-01 22:01:03 AUD-X 5 Min #1 | Reloading chart. | 2018-05-01 22:01:03 Files to Open on Start up | Opening file: 15-30.cht | 2018-05-01 22:01:03 AUD-X 15 Min #3 | Reloading chart. | 2018-05-01 22:01:03 AUD-X 30 Min #1 | Reloading chart. | 2018-05-01 22:01:03 Files to Open on Start up | Opening file: 60-120.cht | 2018-05-01 22:01:03 AUD-X 60 Min #1 | Reloading chart. | 2018-05-01 22:01:03 AUD-X 120 Min #2 | Reloading chart. | 2018-05-01 22:01:03 Files to Open on Start up | Opening file: 240-480.cht | 2018-05-01 22:01:03 AUD-X 240 Min #1 | Reloading chart. | 2018-05-01 22:01:03 AUD-X 480 Min #2 | Reloading chart. | 2018-05-01 22:01:03 Files to Open on Start up | Opening file: 720-960.cht | 2018-05-01 22:01:03 AUD-X 720 Min #1 | Reloading chart. | 2018-05-01 22:01:03 AUD-X 960 Min #2 | Reloading chart. | 2018-05-01 22:01:03 Files to Open on Start up | Opening file: High TF.cht | 2018-05-01 22:01:03 AUD-X Daily #3 | Reloading chart. | 2018-05-01 22:01:03 AUD-X Weekly #1 | Reloading chart. | 2018-05-01 22:01:03 AUD-X Monthly #2 | Reloading chart. | 2018-05-01 22:01:03 Files to Open on Start up | Opening file: Daily-Weekly.cht | 2018-05-01 22:01:03 AUD-X Daily #3 | Reloading chart. | 2018-05-01 22:01:03 AUD-X Monthly #1 | Reloading chart. | 2018-05-01 22:01:03 AUD-X Weekly #2 | Reloading chart. | 2018-05-01 22:01:03 AUD-X Daily #4 | Reloading chart. | 2018-05-01 22:01:03 Using Bid/Ask average for last trade price for AUDCAD | 2018-05-01 22:01:03 Using Bid/Ask average for last trade price for AUDCHF | 2018-05-01 22:01:03 Using Bid/Ask average for last trade price for AUDJPY | 2018-05-01 22:01:03 Using Bid/Ask average for last trade price for AUDNZD | 2018-05-01 22:01:03 Using Bid/Ask average for last trade price for AUDUSD | 2018-05-01 22:01:03 Using Bid/Ask average for last trade price for CADJPY | 2018-05-01 22:01:03 Using Bid/Ask average for last trade price for CADCHF | 2018-05-01 22:01:03 Using Bid/Ask average for last trade price for CHFJPY | 2018-05-01 22:01:03 Using Bid/Ask average for last trade price for EURAUD | 2018-05-01 22:01:03 Using Bid/Ask average for last trade price for EURCAD | 2018-05-01 22:01:03 Using Bid/Ask average for last trade price for EURCHF | 2018-05-01 22:01:03 Using Bid/Ask average for last trade price for EURGBP | 2018-05-01 22:01:03 Using Bid/Ask average for last trade price for EURJPY | 2018-05-01 22:01:03 Using Bid/Ask average for last trade price for EURNZD | 2018-05-01 22:01:03 Using Bid/Ask average for last trade price for EURUSD | 2018-05-01 22:01:03 Using Bid/Ask average for last trade price for GBPAUD | 2018-05-01 22:01:03 Using Bid/Ask average for last trade price for GBPCAD | 2018-05-01 22:01:03 Using Bid/Ask average for last trade price for GBPCHF | 2018-05-01 22:01:03 Using Bid/Ask average for last trade price for GBPJPY | 2018-05-01 22:01:03 Using Bid/Ask average for last trade price for GBPNZD | 2018-05-01 22:01:03 Using Bid/Ask average for last trade price for GBPUSD | 2018-05-01 22:01:03 Using Bid/Ask average for last trade price for NZDCAD | 2018-05-01 22:01:03 Using Bid/Ask average for last trade price for NZDCHF | 2018-05-01 22:01:03 Using Bid/Ask average for last trade price for NZDJPY | 2018-05-01 22:01:03 Using Bid/Ask average for last trade price for NZDUSD | 2018-05-01 22:01:03 Using Bid/Ask average for last trade price for USDCAD | 2018-05-01 22:01:03 Using Bid/Ask average for last trade price for USDCHF | 2018-05-01 22:01:03 Using Bid/Ask average for last trade price for USDJPY | 2018-05-01 22:01:03 Using Bid/Ask average for last trade price for USDSEK | 2018-05-01 22:01:03 Using Bid/Ask average for last trade price for USDSGD | 2018-05-01 22:01:03 Using Bid/Ask average for last trade price for SPX | 2018-05-01 22:01:03 Using Bid/Ask average for last trade price for NDX | 2018-05-01 22:01:03 Using Bid/Ask average for last trade price for WS30 | 2018-05-01 22:01:03 Using Bid/Ask average for last trade price for STOXX50E | 2018-05-01 22:01:03 Using Bid/Ask average for last trade price for FCHI | 2018-05-01 22:01:03 Using Bid/Ask average for last trade price for UK100 | 2018-05-01 22:01:03 Using Bid/Ask average for last trade price for HSI | 2018-05-01 22:01:03 Using Bid/Ask average for last trade price for XAUUSD | 2018-05-01 22:01:03 Using Bid/Ask average for last trade price for XAGUSD | 2018-05-01 22:01:03 Using Bid/Ask average for last trade price for XPDUSD | 2018-05-01 22:01:03 Using Bid/Ask average for last trade price for XPTUSD | 2018-05-01 22:01:03 Using Bid/Ask average for last trade price for XNGUSD | 2018-05-01 22:01:03 Files to Open on Start up | Opening file: Reversal.cht | 2018-05-01 22:01:03 AUD-X 240 Min #1 | Reloading chart. | 2018-05-01 22:01:03 AUD-X Daily #2 | Reloading chart. | 2018-05-01 22:01:03 AUD-X 60 Min #3 | Reloading chart. | 2018-05-01 22:01:03 Intraday data recording state for symbol AUD-X is set to download 'Pending'. | 2018-05-01 22:01:07 HD Request # 2 | Downloading Intraday chart data for AUD-X to the file AUD-X.scid. Service: fxstatscalc | 2018-05-01 22:01:07 HD Request # 2 | Download start date-time: 2018-05-01 21:53:23.000 | 2018-05-01 22:01:07 HD Request # 2 | Using server: lmaxhd.sierracharts.com port 10149 | 2018-05-01 22:01:07 Socket (6) | Creating socket. | 2018-05-01 22:01:07 Socket (6) | Connecting to IP: 65.182.172.42. | 2018-05-01 22:01:07 HD Request # 2 | Setting DTC encoding to Binary VLS | 2018-05-01 22:01:08 HD Request # 2 | Sending historical data logon request message. | 2018-05-01 22:01:08 HD Request # 2 | Requesting Intraday data. Start date-time: 2018-05-01 21:53:23. Record interval: 1. Symbol: AUD-X | 2018-05-01 22:01:08 HD Request # 2 | Decompressing data. | 2018-05-01 22:01:08 HD Request # 2 | Receiving Intraday data for AUD-X starting at 2018-05-01 21:53:23 | 2018-05-01 22:01:08 HD Request # 2 | Timestamp of first Intraday data file record written: 2018-05-01 21:53:23 | 2018-05-01 22:01:08 Socket (6) | Initiating close of socket by core. | 2018-05-01 22:01:08 HD Request # 2 | Historical data for AUD-X is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2018-05-01 22:01:08 Socket (6) | Shutdown started. Waiting for graceful close. | 2018-05-01 22:01:08 Historical data download thread signaled to stop. | 2018-05-01 22:01:08 HD Request # 2 | Received 114 records from 2018-05-01 21:53:23 to 2018-05-01 22:01:03 (7.7 minutes) and wrote 114 records for AUD-X | 2018-05-01 22:01:08 HD Request # 2 | Intraday download COMPLETE for AUD-X. Completion time: 1s. Unique request ID: 1 | 2018-05-01 22:01:08 Removed historical data download ID 1 | 2018-05-01 22:01:08 HD Request # 3 | Downloading Historical Daily chart data for AUD-X. Starting date: 2018-04-30. Service: fxstatscalc | 2018-05-01 22:01:08 HD Request # 3 | Using server: lmaxhd.sierracharts.com port 10150 | 2018-05-01 22:01:08 Socket (6) | Socket gracefully closed by remote side. | 2018-05-01 22:01:08 Socket (6) | Closed. | 2018-05-01 22:01:08 Socket (7) | Creating socket. | 2018-05-01 22:01:08 Socket (7) | Connecting to IP: 65.182.172.42. | 2018-05-01 22:01:08 HD Request # 3 | Setting DTC encoding to Binary VLS | 2018-05-01 22:01:09 HD Request # 3 | Sending historical data logon request message. | 2018-05-01 22:01:09 HD Request # 3 | Requesting historical Daily data starting at 2018-04-30. | 2018-05-01 22:01:09 HD Request # 3 | Decompressing data. | 2018-05-01 22:01:09 HD Request # 3 | Receiving historical Daily data for AUD-X starting at 2018-04-30 | 2018-05-01 22:01:09 HD Request # 3 | Writing historical Daily data to the file AUD-X.dly | 2018-05-01 22:01:09 Socket (7) | Initiating close of socket by core. | 2018-05-01 22:01:09 Socket (7) | Shutdown started. Waiting for graceful close. | 2018-05-01 22:01:09 Historical data download thread signaled to stop. | 2018-05-01 22:01:09 HD Request # 3 | Received 3 records from 2018-04-30 00:00:00 to 2018-05-02 00:00:00 (3.0 days) and wrote 3 records for AUD-X | 2018-05-01 22:01:09 HD Request # 3 | Daily download COMPLETE for AUD-X. Completion time: 0s. Unique request ID: 2 | 2018-05-01 22:01:09 Removed historical data download ID 2 | 2018-05-01 22:01:09 LMAX Demo Trading - DTC | Connecting to the server lmaxtrade1.sierracharts.com. Port 11097 | 2018-05-01 22:01:09 AUD-X Weekly #2 | Reloading chart. | 2018-05-01 22:01:09 Socket (7) | Socket gracefully closed by remote side. | 2018-05-01 22:01:09 Socket (7) | Closed. | 2018-05-01 22:01:09 AUD-X Weekly #1 | Reloading chart. | 2018-05-01 22:01:09 AUD-X Daily #3 | Reloading chart. | 2018-05-01 22:01:09 DTC Client socket (8) | Creating socket. Using TLS 1.2. | 2018-05-01 22:01:09 DTC Client socket (8) | Connecting to IP: 185.95.17.42. | 2018-05-01 22:01:09 AUD-X Daily #2 | Reloading chart. | 2018-05-01 22:01:09 LMAX Demo Trading - DTC | Connected to server. | 2018-05-01 22:01:09 LMAX Demo Trading - DTC | Starting socket receive thread. | 2018-05-01 22:01:09 LMAX Demo Trading - DTC | Sending Encoding Request to server | 2018-05-01 22:01:09 AUD-X Daily #4 | Reloading chart. | 2018-05-01 22:01:09 AUD-X Monthly #2 | Reloading chart. | 2018-05-01 22:01:09 LMAX Demo Trading - DTC | Setting DTC encoding to Binary VLS | 2018-05-01 22:01:09 LMAX Demo Trading - DTC | Sending logon request message. | 2018-05-01 22:01:09 AUD-X Monthly #1 | Reloading chart. | 2018-05-01 22:01:09 LMAX Demo Trading - DTC | Received logon response. | 2018-05-01 22:01:09 LMAX Demo Trading - DTC | Server Name: SC DTC Server. | 2018-05-01 22:01:09 LMAX Demo Trading - DTC | Server protocol version: 8. Client protocol version: 8 | 2018-05-01 22:01:09 LMAX Demo Trading - DTC | Successfully connected. Connected to SC DTC Protocol server. Service=lmaxtrading. | 2018-05-01 22:01:09 LMAX Demo Trading - DTC | Trading is supported. | 2018-05-01 22:01:09 LMAX Demo Trading - DTC | Order cancel and replace is supported. | 2018-05-01 22:01:09 LMAX Demo Trading - DTC | OCO Orders supported. | 2018-05-01 22:01:09 LMAX Demo Trading - DTC | Bracket Orders supported. | 2018-05-01 22:01:09 LMAX Demo Trading - DTC | Connected to data and trading server. | 2018-05-01 22:01:09 Using Bid/Ask average for last trade price for GDAXI | 2018-05-01 22:01:09 LMAX Demo Trading - DTC | Starting real-time market data updates for: GDAXI. ID: 1 | 2018-05-01 22:01:09 LMAX Demo Trading - DTC (Data) | Connecting to the server lmaxrt.sierracharts.com. Port 10048 | 2018-05-01 22:01:09 LMAX Demo Trading - DTC | Requesting security definition data for: GDAXI. ID: 1 | 2018-05-01 22:01:09 Using Bid/Ask average for last trade price for XBRUSD | 2018-05-01 22:01:09 LMAX Demo Trading - DTC | Starting real-time market data updates for: XBRUSD. ID: 2 | 2018-05-01 22:01:09 LMAX Demo Trading - DTC | Requesting security definition data for: XBRUSD. ID: 2 | 2018-05-01 22:01:09 Using Bid/Ask average for last trade price for J225 | 2018-05-01 22:01:09 LMAX Demo Trading - DTC | Starting real-time market data updates for: J225. ID: 3 | 2018-05-01 22:01:09 LMAX Demo Trading - DTC | Requesting security definition data for: J225. ID: 3 | 2018-05-01 22:01:09 Using Bid/Ask average for last trade price for XTIUSD | 2018-05-01 22:01:09 LMAX Demo Trading - DTC | Starting real-time market data updates for: XTIUSD. ID: 4 | 2018-05-01 22:01:09 LMAX Demo Trading - DTC | Requesting security definition data for: XTIUSD. ID: 4 | 2018-05-01 22:01:09 LMAX Demo Trading - DTC | Starting real-time market data updates for: AUD-X. ID: 5 | 2018-05-01 22:01:09 LMAX Demo Trading - DTC | Requesting security definition data for: AUD-X. ID: 5 | 2018-05-01 22:01:09 Intraday data recording state for symbol AUD-X is set to download 'Pending'. | 2018-05-01 22:01:09 Delaying start of download for AUD-X | 2018-05-01 22:01:09 AUD-X Daily #3 | Reloading chart. | 2018-05-01 22:01:09 LMAX Demo Trading - DTC | Received security definition for symbol GDAXI | 2018-05-01 22:01:09 LMAX Demo Trading - DTC | Received security definition for symbol XBRUSD | 2018-05-01 22:01:09 LMAX Demo Trading - DTC | Received security definition for symbol J225 | 2018-05-01 22:01:09 LMAX Demo Trading - DTC | Received security definition for symbol XTIUSD | 2018-05-01 22:01:09 LMAX Demo Trading - DTC | Received security definition for symbol AUD-X | 2018-05-01 22:01:09 Using Bid/Ask average for last trade price for AUDCAD | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Starting real-time market data updates for: AUDCAD. ID: 6 | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Requesting security definition data for: AUDCAD. ID: 6 | 2018-05-01 22:01:10 Using Bid/Ask average for last trade price for AUDCHF | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Starting real-time market data updates for: AUDCHF. ID: 7 | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Requesting security definition data for: AUDCHF. ID: 7 | 2018-05-01 22:01:10 Using Bid/Ask average for last trade price for AUDJPY | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Starting real-time market data updates for: AUDJPY. ID: 8 | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Requesting security definition data for: AUDJPY. ID: 8 | 2018-05-01 22:01:10 Using Bid/Ask average for last trade price for AUDNZD | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Starting real-time market data updates for: AUDNZD. ID: 9 | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Requesting security definition data for: AUDNZD. ID: 9 | 2018-05-01 22:01:10 Using Bid/Ask average for last trade price for AUDUSD | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Starting real-time market data updates for: AUDUSD. ID: 10 | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Requesting security definition data for: AUDUSD. ID: 10 | 2018-05-01 22:01:10 Using Bid/Ask average for last trade price for CADJPY | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Starting real-time market data updates for: CADJPY. ID: 11 | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Requesting security definition data for: CADJPY. ID: 11 | 2018-05-01 22:01:10 Using Bid/Ask average for last trade price for CADCHF | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Starting real-time market data updates for: CADCHF. ID: 12 | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Requesting security definition data for: CADCHF. ID: 12 | 2018-05-01 22:01:10 Using Bid/Ask average for last trade price for CHFJPY | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Starting real-time market data updates for: CHFJPY. ID: 13 | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Requesting security definition data for: CHFJPY. ID: 13 | 2018-05-01 22:01:10 Using Bid/Ask average for last trade price for EURAUD | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Starting real-time market data updates for: EURAUD. ID: 14 | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Requesting security definition data for: EURAUD. ID: 14 | 2018-05-01 22:01:10 Using Bid/Ask average for last trade price for EURCAD | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Starting real-time market data updates for: EURCAD. ID: 15 | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Requesting security definition data for: EURCAD. ID: 15 | 2018-05-01 22:01:10 Using Bid/Ask average for last trade price for EURCHF | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Starting real-time market data updates for: EURCHF. ID: 16 | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Requesting security definition data for: EURCHF. ID: 16 | 2018-05-01 22:01:10 Using Bid/Ask average for last trade price for EURGBP | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Starting real-time market data updates for: EURGBP. ID: 17 | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Requesting security definition data for: EURGBP. ID: 17 | 2018-05-01 22:01:10 Using Bid/Ask average for last trade price for EURJPY | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Starting real-time market data updates for: EURJPY. ID: 18 | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Requesting security definition data for: EURJPY. ID: 18 | 2018-05-01 22:01:10 Using Bid/Ask average for last trade price for EURNZD | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Starting real-time market data updates for: EURNZD. ID: 19 | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Requesting security definition data for: EURNZD. ID: 19 | 2018-05-01 22:01:10 Using Bid/Ask average for last trade price for EURUSD | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Starting real-time market data updates for: EURUSD. ID: 20 | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Requesting security definition data for: EURUSD. ID: 20 | 2018-05-01 22:01:10 Using Bid/Ask average for last trade price for GBPAUD | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Starting real-time market data updates for: GBPAUD. ID: 21 | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Requesting security definition data for: GBPAUD. ID: 21 | 2018-05-01 22:01:10 Using Bid/Ask average for last trade price for GBPCAD | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Starting real-time market data updates for: GBPCAD. ID: 22 | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Requesting security definition data for: GBPCAD. ID: 22 | 2018-05-01 22:01:10 Using Bid/Ask average for last trade price for GBPCHF | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Starting real-time market data updates for: GBPCHF. ID: 23 | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Requesting security definition data for: GBPCHF. ID: 23 | 2018-05-01 22:01:10 Using Bid/Ask average for last trade price for GBPJPY | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Starting real-time market data updates for: GBPJPY. ID: 24 | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Requesting security definition data for: GBPJPY. ID: 24 | 2018-05-01 22:01:10 Using Bid/Ask average for last trade price for GBPNZD | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Starting real-time market data updates for: GBPNZD. ID: 25 | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Requesting security definition data for: GBPNZD. ID: 25 | 2018-05-01 22:01:10 Using Bid/Ask average for last trade price for GBPUSD | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Starting real-time market data updates for: GBPUSD. ID: 26 | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Requesting security definition data for: GBPUSD. ID: 26 | 2018-05-01 22:01:10 Using Bid/Ask average for last trade price for NZDCAD | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Starting real-time market data updates for: NZDCAD. ID: 27 | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Requesting security definition data for: NZDCAD. ID: 27 | 2018-05-01 22:01:10 Using Bid/Ask average for last trade price for NZDCHF | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Starting real-time market data updates for: NZDCHF. ID: 28 | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Requesting security definition data for: NZDCHF. ID: 28 | 2018-05-01 22:01:10 Using Bid/Ask average for last trade price for NZDJPY | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Starting real-time market data updates for: NZDJPY. ID: 29 | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Requesting security definition data for: NZDJPY. ID: 29 | 2018-05-01 22:01:10 Using Bid/Ask average for last trade price for NZDUSD | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Starting real-time market data updates for: NZDUSD. ID: 30 | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Requesting security definition data for: NZDUSD. ID: 30 | 2018-05-01 22:01:10 Using Bid/Ask average for last trade price for USDCAD | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Starting real-time market data updates for: USDCAD. ID: 31 | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Requesting security definition data for: USDCAD. ID: 31 | 2018-05-01 22:01:10 Using Bid/Ask average for last trade price for USDCHF | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Starting real-time market data updates for: USDCHF. ID: 32 | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Requesting security definition data for: USDCHF. ID: 32 | 2018-05-01 22:01:10 Using Bid/Ask average for last trade price for USDJPY | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Starting real-time market data updates for: USDJPY. ID: 33 | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Requesting security definition data for: USDJPY. ID: 33 | 2018-05-01 22:01:10 Using Bid/Ask average for last trade price for USDSEK | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Starting real-time market data updates for: USDSEK. ID: 34 | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Requesting security definition data for: USDSEK. ID: 34 | 2018-05-01 22:01:10 Using Bid/Ask average for last trade price for USDSGD | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Starting real-time market data updates for: USDSGD. ID: 35 | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Requesting security definition data for: USDSGD. ID: 35 | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Starting real-time market data updates for: CAD-X. ID: 36 | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Requesting security definition data for: CAD-X. ID: 36 | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Starting real-time market data updates for: CHF-X. ID: 37 | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Requesting security definition data for: CHF-X. ID: 37 | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Starting real-time market data updates for: EUR-X. ID: 38 | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Requesting security definition data for: EUR-X. ID: 38 | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Starting real-time market data updates for: GBP-X. ID: 39 | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Requesting security definition data for: GBP-X. ID: 39 | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Starting real-time market data updates for: JPY-X. ID: 40 | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Requesting security definition data for: JPY-X. ID: 40 | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Starting real-time market data updates for: NZD-X. ID: 41 | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Requesting security definition data for: NZD-X. ID: 41 | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Starting real-time market data updates for: USD-X. ID: 42 | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Requesting security definition data for: USD-X. ID: 42 | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Starting real-time market data updates for: USDX. ID: 43 | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Requesting security definition data for: USDX. ID: 43 | 2018-05-01 22:01:10 Using Bid/Ask average for last trade price for SPX | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Starting real-time market data updates for: SPX. ID: 44 | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Requesting security definition data for: SPX. ID: 44 | 2018-05-01 22:01:10 Using Bid/Ask average for last trade price for NDX | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Starting real-time market data updates for: NDX. ID: 45 | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Requesting security definition data for: NDX. ID: 45 | 2018-05-01 22:01:10 Using Bid/Ask average for last trade price for WS30 | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Starting real-time market data updates for: WS30. ID: 46 | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Requesting security definition data for: WS30. ID: 46 | 2018-05-01 22:01:10 Using Bid/Ask average for last trade price for STOXX50E | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Starting real-time market data updates for: STOXX50E. ID: 47 | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Requesting security definition data for: STOXX50E. ID: 47 | 2018-05-01 22:01:10 Using Bid/Ask average for last trade price for FCHI | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Starting real-time market data updates for: FCHI. ID: 48 | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Requesting security definition data for: FCHI. ID: 48 | 2018-05-01 22:01:10 Using Bid/Ask average for last trade price for UK100 | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Starting real-time market data updates for: UK100. ID: 49 | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Requesting security definition data for: UK100. ID: 49 | 2018-05-01 22:01:10 Using Bid/Ask average for last trade price for HSI | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Starting real-time market data updates for: HSI. ID: 50 | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Requesting security definition data for: HSI. ID: 50 | 2018-05-01 22:01:10 Using Bid/Ask average for last trade price for XAUUSD | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Starting real-time market data updates for: XAUUSD. ID: 51 | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Requesting security definition data for: XAUUSD. ID: 51 | 2018-05-01 22:01:10 Using Bid/Ask average for last trade price for XAGUSD | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Starting real-time market data updates for: XAGUSD. ID: 52 | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Requesting security definition data for: XAGUSD. ID: 52 | 2018-05-01 22:01:10 Using Bid/Ask average for last trade price for XPDUSD | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Starting real-time market data updates for: XPDUSD. ID: 53 | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Requesting security definition data for: XPDUSD. ID: 53 | 2018-05-01 22:01:10 Using Bid/Ask average for last trade price for XPTUSD | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Starting real-time market data updates for: XPTUSD. ID: 54 | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Requesting security definition data for: XPTUSD. ID: 54 | 2018-05-01 22:01:10 Using Bid/Ask average for last trade price for XNGUSD | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Starting real-time market data updates for: XNGUSD. ID: 55 | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Requesting security definition data for: XNGUSD. ID: 55 | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Received security definition for symbol AUDCAD | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Received security definition for symbol AUDCHF | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Received security definition for symbol AUDJPY | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Received security definition for symbol AUDNZD | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Received security definition for symbol AUDUSD | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Received security definition for symbol CADJPY | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Received security definition for symbol CADCHF | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Received security definition for symbol CHFJPY | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Received security definition for symbol EURAUD | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Received security definition for symbol EURCAD | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Received security definition for symbol EURCHF | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Received security definition for symbol EURGBP | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Received security definition for symbol EURJPY | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Received security definition for symbol EURNZD | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Received security definition for symbol EURUSD | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Received security definition for symbol GBPAUD | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Received security definition for symbol GBPCAD | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Received security definition for symbol GBPCHF | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Received security definition for symbol GBPJPY | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Received security definition for symbol GBPNZD | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Received security definition for symbol GBPUSD | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Received security definition for symbol NZDCAD | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Received security definition for symbol NZDCHF | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Received security definition for symbol NZDJPY | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Received security definition for symbol NZDUSD | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Received security definition for symbol USDCAD | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Received security definition for symbol USDCHF | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Received security definition for symbol USDJPY | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Received security definition for symbol USDSEK | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Received security definition for symbol USDSGD | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Received security definition for symbol CAD-X | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Received security definition for symbol CHF-X | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Received security definition for symbol EUR-X | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Received security definition for symbol GBP-X | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Received security definition for symbol JPY-X | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Received security definition for symbol NZD-X | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Received security definition for symbol USD-X | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Received security definition for symbol USDX | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Received security definition for symbol SPX | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Received security definition for symbol NDX | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Received security definition for symbol WS30 | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Received security definition for symbol STOXX50E | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Received security definition for symbol FCHI | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Received security definition for symbol UK100 | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Received security definition for symbol HSI | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Received security definition for symbol XAUUSD | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Received security definition for symbol XAGUSD | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Received security definition for symbol XPDUSD | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Received security definition for symbol XPTUSD | 2018-05-01 22:01:10 LMAX Demo Trading - DTC | Received security definition for symbol XNGUSD | 2018-05-01 22:01:10 DTC Client socket (9) | Creating socket. | 2018-05-01 22:01:10 DTC Client socket (9) | Connecting to IP: 185.95.17.42. | 2018-05-01 22:01:10 LMAX Demo Trading - DTC (Data) | Connected to server. | 2018-05-01 22:01:10 LMAX Demo Trading - DTC (Data) | Starting socket receive thread. | 2018-05-01 22:01:10 LMAX Demo Trading - DTC (Data) | Sending Encoding Request to server | 2018-05-01 22:01:10 LMAX Demo Trading - DTC (Data) | Setting DTC encoding to Binary VLS | 2018-05-01 22:01:10 LMAX Demo Trading - DTC (Data) | Sending logon request message. | 2018-05-01 22:01:10 LMAX Demo Trading - DTC (Data) | Received logon response. | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Server Name: SC Realtime Server. | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Server protocol version: 8. Client protocol version: 8 | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Successfully connected. | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Trading is not supported. | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Restarting real-time data updates for symbol: AUD-X | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Restarting real-time data updates for symbol: AUDCAD | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Restarting real-time data updates for symbol: AUDCHF | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Restarting real-time data updates for symbol: AUDJPY | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Restarting real-time data updates for symbol: AUDNZD | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Restarting real-time data updates for symbol: AUDUSD | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Restarting real-time data updates for symbol: CAD-X | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Restarting real-time data updates for symbol: CADCHF | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Restarting real-time data updates for symbol: CADJPY | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Restarting real-time data updates for symbol: CHF-X | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Restarting real-time data updates for symbol: CHFJPY | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Restarting real-time data updates for symbol: EUR-X | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Restarting real-time data updates for symbol: EURAUD | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Restarting real-time data updates for symbol: EURCAD | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Restarting real-time data updates for symbol: EURCHF | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Restarting real-time data updates for symbol: EURGBP | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Restarting real-time data updates for symbol: EURJPY | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Restarting real-time data updates for symbol: EURNZD | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Restarting real-time data updates for symbol: EURUSD | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Restarting real-time data updates for symbol: FCHI | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Restarting real-time data updates for symbol: GBP-X | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Restarting real-time data updates for symbol: GBPAUD | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Restarting real-time data updates for symbol: GBPCAD | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Restarting real-time data updates for symbol: GBPCHF | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Restarting real-time data updates for symbol: GBPJPY | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Restarting real-time data updates for symbol: GBPNZD | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Restarting real-time data updates for symbol: GBPUSD | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Restarting real-time data updates for symbol: GDAXI | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Restarting real-time data updates for symbol: HSI | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Restarting real-time data updates for symbol: J225 | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Restarting real-time data updates for symbol: JPY-X | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Restarting real-time data updates for symbol: NDX | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Restarting real-time data updates for symbol: NZD-X | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Restarting real-time data updates for symbol: NZDCAD | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Restarting real-time data updates for symbol: NZDCHF | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Restarting real-time data updates for symbol: NZDJPY | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Restarting real-time data updates for symbol: NZDUSD | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Restarting real-time data updates for symbol: SPX | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Restarting real-time data updates for symbol: STOXX50E | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Restarting real-time data updates for symbol: UK100 | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Restarting real-time data updates for symbol: USD-X | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Restarting real-time data updates for symbol: USDCAD | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Restarting real-time data updates for symbol: USDCHF | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Restarting real-time data updates for symbol: USDJPY | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Restarting real-time data updates for symbol: USDSEK | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Restarting real-time data updates for symbol: USDSGD | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Restarting real-time data updates for symbol: USDX | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Restarting real-time data updates for symbol: WS30 | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Restarting real-time data updates for symbol: XAGUSD | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Restarting real-time data updates for symbol: XAUUSD | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Restarting real-time data updates for symbol: XBRUSD | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Restarting real-time data updates for symbol: XNGUSD | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Restarting real-time data updates for symbol: XPDUSD | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Restarting real-time data updates for symbol: XPTUSD | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Restarting real-time data updates for symbol: XTIUSD | 2018-05-01 22:01:11 Symbol Error - AUD-X is unknown, unavailable, or improperly formatted. Symbol service code not specified. | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Received security definition for symbol AUDCAD | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Received security definition for symbol AUDCHF | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Received security definition for symbol AUDJPY | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Received security definition for symbol AUDNZD | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Received security definition for symbol AUDUSD | 2018-05-01 22:01:11 Symbol Error - CAD-X is unknown, unavailable, or improperly formatted. Symbol service code not specified. | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Received security definition for symbol CADCHF | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Received security definition for symbol CADJPY | 2018-05-01 22:01:11 Symbol Error - CHF-X is unknown, unavailable, or improperly formatted. Symbol service code not specified. | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Received security definition for symbol CHFJPY | 2018-05-01 22:01:11 Symbol Error - EUR-X is unknown, unavailable, or improperly formatted. Symbol service code not specified. | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Received security definition for symbol EURAUD | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Received security definition for symbol EURCAD | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Received security definition for symbol EURCHF | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Received security definition for symbol EURGBP | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Received security definition for symbol EURJPY | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Received security definition for symbol EURNZD | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Received security definition for symbol EURUSD | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Received security definition for symbol FCHI | 2018-05-01 22:01:11 Symbol Error - GBP-X is unknown, unavailable, or improperly formatted. Symbol service code not specified. | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Received security definition for symbol GBPAUD | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Received security definition for symbol GBPCAD | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Received security definition for symbol GBPCHF | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Received security definition for symbol GBPJPY | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Received security definition for symbol GBPNZD | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Received security definition for symbol GBPUSD | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Received security definition for symbol GDAXI | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Received security definition for symbol HSI | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Received security definition for symbol J225 | 2018-05-01 22:01:11 Symbol Error - JPY-X is unknown, unavailable, or improperly formatted. Symbol service code not specified. | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Received security definition for symbol NDX | 2018-05-01 22:01:11 Symbol Error - NZD-X is unknown, unavailable, or improperly formatted. Symbol service code not specified. | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Received security definition for symbol NZDCAD | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Received security definition for symbol NZDCHF | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Received security definition for symbol NZDJPY | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Received security definition for symbol NZDUSD | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Received security definition for symbol SPX | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Received security definition for symbol STOXX50E | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Received security definition for symbol UK100 | 2018-05-01 22:01:11 Symbol Error - USD-X is unknown, unavailable, or improperly formatted. Symbol service code not specified. | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Received security definition for symbol USDCAD | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Received security definition for symbol USDCHF | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Received security definition for symbol USDJPY | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Received security definition for symbol USDSEK | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Received security definition for symbol USDSGD | 2018-05-01 22:01:11 Symbol Error - USDX is unknown, unavailable, or improperly formatted. Symbol service code not specified. | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Received security definition for symbol WS30 | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Received security definition for symbol XAGUSD | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Received security definition for symbol XAUUSD | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Received security definition for symbol XBRUSD | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Received security definition for symbol XNGUSD | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Received security definition for symbol XPDUSD | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Received security definition for symbol XPTUSD | 2018-05-01 22:01:11 LMAX Demo Trading - DTC (Data) | Received security definition for symbol XTIUSD | 2018-05-01 22:01:11 HD Request # 4 | Downloading Intraday chart data for AUD-X to the file AUD-X.scid. Service: fxstatscalc | 2018-05-01 22:01:11 HD Request # 4 | Download start date-time: 2018-05-01 22:01:03.000 | 2018-05-01 22:01:11 HD Request # 4 | Using server: lmaxhd.sierracharts.com port 10149 | 2018-05-01 22:01:11 Socket (10) | Creating socket. | 2018-05-01 22:01:11 Socket (10) | Connecting to IP: 65.182.172.42. | 2018-05-01 22:01:11 HD Request # 4 | Setting DTC encoding to Binary VLS | 2018-05-01 22:01:11 HD Request # 4 | Sending historical data logon request message. | 2018-05-01 22:01:11 HD Request # 4 | Requesting Intraday data. Start date-time: 2018-05-01 22:01:03. Record interval: 1. Symbol: AUD-X | 2018-05-01 22:01:11 HD Request # 4 | Decompressing data. | 2018-05-01 22:01:11 HD Request # 4 | Receiving Intraday data for AUD-X starting at 2018-05-01 22:01:03 | 2018-05-01 22:01:11 HD Request # 4 | Timestamp of first Intraday data file record written: 2018-05-01 22:01:03 | 2018-05-01 22:01:11 Socket (10) | Initiating close of socket by core. | 2018-05-01 22:01:11 Socket (10) | Shutdown started. Waiting for graceful close. | 2018-05-01 22:01:11 Historical data download thread signaled to stop. | 2018-05-01 22:01:11 HD Request # 4 | Received 2 records from 2018-05-01 22:01:03 to 2018-05-01 22:01:07 (4.0 seconds) and wrote 2 records for AUD-X | 2018-05-01 22:01:11 HD Request # 4 | Intraday download COMPLETE for AUD-X. Completion time: 0s. Unique request ID: 3 | 2018-05-01 22:01:11 Removed historical data download ID 3 | 2018-05-01 22:01:11 Real-time Intraday chart data file updates started for AUD-X | 2018-05-01 22:01:11 Opened cached Intraday file: C:\SierraChart\Data\AUD-X.scid | 2018-05-01 22:01:11 Intraday chart data file opened for AUD-X | 2018-05-01 22:01:11 Socket (10) | Socket gracefully closed by remote side. | 2018-05-01 22:01:11 Socket (10) | Closed. | 2018-05-01 22:01:11 |
[2018-05-01 21:16:59] |
We see you are running an older version of Sierra Chart. Most likely this is the reason for the problem. In any case you really must update. Follow the instructions here: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-05-01 21:17:14
