Date/Time: Sun, 19 Jan 2025 17:45:15 +0000
notes on dom
View Count: 1359
[2018-04-30 13:15:59] |
User875891 - Posts: 63 |
Is there a way to make notes on dom? or arrows? |
[2018-04-30 18:40:18] |
Yes, you can use the Stationary Text tool: Chart Drawing Tools: Type Text | Stationary Text This is accessed through Chart >> Tools. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-05-01 15:31:34] |
chart>>tools are not shown as dom headings
[2018-05-01 17:49:08] |
On the Trading DOM there is definitively a Chart >> Tools submenu. Look again.
