Date/Time: Sun, 19 Jan 2025 17:44:25 +0000
Daily OHLC Study Question
View Count: 1146
[2018-04-30 13:04:15] |
ecerejo - Posts: 16 |
http://www.sierrachart.com/image.php?Image=1525093169385.png Why am I getting a diagonal line when it changes to the next session when I have it configured to show only the previous day high and low? |
[2018-04-30 18:55:34] |
The reason the diagonal line is showing is because the Subgraph has been set to Line from the default of Dash. If you change the Subgraph back to Dash, then you will not see the diagonal line. You can find the information on these Draw Styles here: Chart Studies: Subgraphs Tab >> Draw Style Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-04-30 18:55:58
[2018-04-30 23:56:31] |
User106180 - Posts: 88 |
Reload and Recalculate of the chart (within the Chart menu) will fix this. For charts that I have this study on, I have to do this at the start of every day.
[2018-05-01 00:17:54] |
OK we understand now. If you have the Daily OHLC study set to calculate only 1 day, it is necessary to select Chart >> Reload and Recalculate to clear the prior results. This is not any type of malfunction. This is just by design. The prior data is not going to get cleared automatically. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-05-01 00:18:20
