Date/Time: Sun, 19 Jan 2025 23:19:02 +0000
Only 1 sheet showing in Chartbook
View Count: 931
[2018-04-30 12:48:25]
User852663 - Posts: 21
I have a chartbook put together by someone else from a while ago and never had issues opening before but now when I open it there is only 1 chart showing even though I know there are numerous charts within the chartbook. I think there was a fix for this mentioned in a sticky but I can't find anything now. I am running version 1733
[2018-04-30 18:52:58]
Here is the reference you are thinking of. See if this relates to the problem you are having:
Version 1731 Only Opens One Chart from Chartbook
[2018-05-13 00:58:36]
I noticed that this problem only occurs when I run SC in 64 bit and is reproducible every time. Any idea what could be done to fix this?
[2018-05-13 01:02:17]
Update to version 1745:
Let us know if you still see the issue.
[2018-05-14 13:58:57]
That fixed it. Charts work fine in 1745 64 bit now. Thanks very much for the quick response, especially over the weekend.
