Date/Time: Mon, 20 Jan 2025 17:01:11 +0000
Numbers Bars Calculated Values - extra subgraph request
View Count: 1766
[2018-04-30 09:25:08] |
User106180 - Posts: 88 |
Would it be possible in the 'Numbers Bar Calculated Values' study (https://www.sierrachart.com/index.php?page=doc/NumbersBars.php#s300 ), to make a subgraph for the 'Cumulative Delta Bars - Up/Down Tick Volume' study (Cumulative Delta Bars - Up/Down Tick Volume )? Thanks Date Time Of Last Edit: 2018-05-14 18:42:15
[2018-05-11 02:14:04] |
Any news on this? I know you're very busy but it would be great if you could add it. Thank you
[2018-05-14 18:08:35] |
John - SC Support - Posts: 37327 |
Yes, we are working on this. We are going to set it up to reset with each day. If there is any reason it should be otherwise, let us know. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-05-15 14:42:14] |
This has been added and will be in release 1746.
[2018-06-06 06:12:31] |
I can see that Cumulative Delta Up/Down Tick Volume (SG47) has been added. Can you please add the ability to change the colour based on +ve/-ve as you can for other subgraphs? Also, is it possible to add a subgraph for: 1) Total Up/Down Tick Volume 2) Up Tick Volume - Down Tick Volume (or vice versa) Thanks. |
[2018-06-06 16:11:53] |
This ability has been there since the release of that Subgraph. We have tested and verified that it is working. If you are turning on the option for Color Background Based on Value Percentage and still not getting the background coloring like the other Subgraphs, then please attach a Chartbook to this thread so we can see why this might be happening.Also, is it possible to add a subgraph for:
Yes, we can add these. Give us a few days to get them done.
1) Total Up/Down Tick Volume 2) Up Tick Volume - Down Tick Volume (or vice versa) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-06-13 16:16:22] |
Sorry for the delay, but we finally had a chance to add the new items into the Numbers Bars Calculated Values study. It will be available in the next release - 1765. Look for this on the main webpage under the PreRelease. When available, you can update to the new release following these instructions: Software Download: Fast Update The new subgraphs are at the bottom of the list and are named Total Up Tick Volume, Total Down Tick Volume, and Up Down Tick Volume Difference. The latter subgraph is the Total Up Tick Volume minus the Total Down Tick Volume. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-07-02 23:38:19] |
Thank you for this. Is it possible to include Total Up AND Down Tick Volume (not up and down separately)?
[2018-07-03 13:56:57] |
Unfortunately, we are running out of the available slots to add additional items to the Numbers Bars Calculated Values. Since this is an item that can easily be calculated using another study such as Study Subgraphs Add, we are going to have to decline adding this to the Numbers Bars Calculated Values.
[2018-07-04 10:21:53] |
I understand. I was just requesting it calculated within Cumulative Delta Bars - Up/Down Tick Volume, and there are other similar kinds of calculations within Cumulative Delta Bars. Thank you |
