Date/Time: Mon, 20 Jan 2025 08:20:24 +0000
Normalized Average True Range
View Count: 2198
[2018-04-30 03:32:51] |
User401511 - Posts: 33 |
Hi SC, Couldn't find any info on Normalized Average True Range (ATR) indicator in SC. Do you think you can build one for future updates. Here is some info on it. The formula looks right from what I have looked at. https://www.tradingtechnologies.com/help/x-study/technical-indicator-definitions/normalized-average-true-range-natr/ Thanks! |
[2018-04-30 19:49:40] |
We will have a look at this.
[2018-05-31 22:35:06] |
I could probably find a user that has coded this?
[2018-06-01 00:45:38] |
This actually has been added. You will find it in Analysis >> Studies: Average True Range-Normalized. Update to the current version following these instructions: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-06-01 00:45:53
