Date/Time: Sun, 19 Jan 2025 17:49:33 +0000
Data Delay
View Count: 1216
[2018-04-30 01:50:33] |
User895936 - Posts: 4 |
Hi I am a new subscriber to Sierra Charts and trying it out to see how it works. My chart data is delayed on my charts. For example it is showing data till 9:30 pm but its 9:47 here is Toronto. How can I fix it please? Also how can I import indicators on sierra charts? i have followed instructions posted on your website but it does not work. Thanks khalid |
[2018-04-30 05:38:05] |
If you are referring to real-time futures data, then refer to: Is Historical and Real-time Futures Data Included? Also how can I import indicators on sierra charts?
Make sure you are not running the 64-bit version. Refer to:How to Use an Advanced Custom Study or a Study Collection: Custom Study Not Listed or Not Displaying on Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-05-01 05:09:17] |
Hi How can i use the Market Depth Historical Graph on my charts? I believe I need to do some settings changes before I can use this study. I am using the SC Data feed as I am using the trial version for now. Thank you khalid Date Time Of Last Edit: 2018-05-01 16:17:41
[2018-05-01 17:26:21] |
You cannot unless Sierra Chart is connected to a real-time data feed which also provides market depth data for the symbol that you want to use with the Market Depth Historical Graph study.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-05-01 21:47:49
[2018-05-01 19:39:55] |
In order to use the Market Depth Historical Graph, you first need to have access to the exchange data with Market Depth. You can find the specific information on which exchanges are supported in the Sierra Chart Real-Time Data Feed here: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#SupportedExchanges Assuming you want to use this data feed. And then follow the Setup Instructions found here to pay for and activate this data feed: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#SetupInstructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-05-01 19:40:33
