Date/Time: Tue, 22 Sep 2026 08:02:15 +0000
[Programming Help] - howto break(for) loop at first bar in history?
View Count: 1018
[2018-04-29 21:41:52]
TedMar - Posts: 191
sc.AutoLoop = 1;
// LOOP
for (int i = 1; MovingAverage1[sc.Index -(i)] > MovingAverage2[sc.Index -(i)];i++)
howto Break loop at first bar in history ?
if not break the loop at first histry bar and "for" is true , then freezes Sierrachart.
Date Time Of Last Edit: 2018-04-29 21:43:46
[2018-04-29 22:19:35]
To check for the first bar you need to use:
sc.Index == 0
Date Time Of Last Edit: 2018-04-29 22:19:46
[2018-04-30 08:45:14]
TedMar - Posts: 191
hmm, the (for)loop count bars from latest (Current Bar right in chart) to left bar in chart (first bar in history sc.index == 0).
But howto check first bar after increment before starts next loop?
I tryed example :
sc.AutoLoop = 1;
//LOOP
for (int i = 1; sc.Index == 0 && MovingAverage1[sc.Index -(i)] > MovingAverage2[sc.Index -(i)];i++)
sc.Subgraph[0][sc.Index - (i)] = [sc.Index - (i)]; // fill arrows between Avg1 > Avg2
after add "sc.Index == 0" , doesn't work fill the loop "true" space in subgraph. in dont understand stand why? Any idea to resolve this problem?
