Date/Time: Sun, 19 Jan 2025 17:59:43 +0000
price study overlay
View Count: 758
[2018-04-29 19:55:42] |
User228927 - Posts: 55 |
The color background study was overlayed from chart #3 to chart #5. They were perfectly matched. Made some changes to the background conditions in #3 and the overlay never changed in chart #5. I assumed once you made changes to chart #3 the changes would be automatically changed in chart #5.
UploadImage.png / V - Attached On 2018-04-29 19:55:05 UTC - Size: 84.28 KB - 252 views |
[2018-04-30 01:49:32] |
Yes, this should be the case. If you go to Chart #5, and select Chart >> Recalculate, do you then see the change in chart #5? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
