Date/Time: Sun, 19 Jan 2025 18:01:58 +0000
Performance Data - Follow up
View Count: 750
[2018-04-29 18:49:04]
QnReally - Posts: 181
Dear Support,
My request has been marked as a "user discussion": Performance data
I would like to understand the following if it doesn't consume too much of your time. Just yes/no answers would be fine.
1) You want to see how many other people want this enhancement?
2) ACSIL already supports access to the performance data and other people may be able to help with some suggestions?
3) Either this requires too many of your resources for the enhancement and this is not a priority and/or not that useful in your opinion?
It is fine if you cannot take this request. I will be grateful if you put it on your roadmap but it is not an absolute need. However, I will say that it will improve the perceived quality your product and decrease the support requests relating to the performance issues when they use SC in a weird configuration.
Thanks.
[2018-04-30 19:48:56]
1. Yes
2. Yes, much of what you suggest can be done through ACSIL.
3. It is not a priority. We have a lot to do and we consider every suggestion that is given. But there is simply not the time to do every request.
