Date/Time: Sun, 19 Jan 2025 23:14:40 +0000
SuperTrend Stop Study
View Count: 3041
[2018-04-29 18:38:44] |
User1967 - Posts: 34 |
There is a Study "Super Trend Stop" available in Sierra. However, there is no study description available on the study itself or its settings. Where we can get some information on this study and formula this indicator uses? Regards, GH Sabri |
[2018-04-29 18:40:38] |
Hello, Is there a way that we can read a .txt file and draw the support/resistance zones/lines (a sample file attached)? Regards, GH Sabri |
Zones.txt - Attached On 2018-04-29 18:40:09 UTC - Size: 2.69 KB - 517 views |
[2018-04-30 18:48:31] |
The source code for that study is provided. Refer to the instructions here: How to Build an Advanced Custom Study from Source Code: Searching for Source Code for Sierra Chart Built-In Studies There is no study available to read a text file and draw horizontal lines from it. You could look at using the Horizontal Lines study instead: Horizontal Lines Also refer to this particular study: Trading Levels Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-04-30 18:50:47
