Date/Time: Thu, 28 Nov 2024 00:06:52 +0000
moving average shift
View Count: 2499
[2013-10-08 19:18:54] |
M5amhan - Posts: 468 |
normally a moving average only needs the number of days to load equal (or exceed by a few) to the length to plot accurately.. my longest moving average on here is the 200sma (brown) and when i only load 400 days my 144ema (orange) is off but my 200sma is still the same. do you know why this is happening? http://www.sierrachart.com/image.php?l=1381259682907.png - days to load = 600 http://www.sierrachart.com/image.php?l=1381259763907.png - days to load = 400 if you open both links and click back and forth through the tab you can see it shift |
[2013-10-09 03:45:04] |
JohnL - Posts: 27 |
This is true for SMA, but not so for EMA. For an EMA the starting data points are always part of the final result, so you need to load enough data so that this startup effect is small. Try loading more data until you don't see a difference when changing data length. |
[2013-10-09 03:58:18] |
Exponential moving averages will be affected by the changing number of days in a chart. If you research how the calculation is done, you will see why. We wonder why they are so popular.
