Date/Time: Sun, 19 Jan 2025 17:43:40 +0000
Quote Board Bug
View Count: 688
[2018-04-28 00:02:25] |
User41727 - Posts: 124 |
When I have a Quote Board containing several symbols and labels and I try to remove the currently selected symbol by pressing delete on the keyboard, the last symbol in this section (separated by the labels) and the the last symbol on the QB overall are both duplicated. The symbol itself is removed. This happens with all versions since (and including) 1729. Both QBs that were created with an earlier version of SC as well as newly created QBs are affected. |
[2018-04-29 12:04:22] |
This will be solved in the next release.
