Date/Time: Sun, 19 Jan 2025 18:01:31 +0000
Numbers Bars
View Count: 685
[2018-04-27 15:21:27] |
John R D - Posts: 25 |
Hi I noticed with numbers bars I have to keep adjusting the size of the of the numbers to see them clearly. Is there a solution to get them to adjust constantly to be clearly visible with out manually fixing it. John |
[2018-04-27 18:32:59] |
No, this is not supported. However, refer to this information here: Numbers Bars: Scaling a Numbers Bars Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-04-27 18:33:19
