Date/Time: Sun, 19 Jan 2025 18:01:44 +0000
data just cut out in middle of trade please help asap
View Count: 625
[2018-04-27 14:59:21] |
jackdaddy - Posts: 10 |
no data disconnect and reconnect
[2018-04-27 15:25:28] |
So you are saying there was an interruption in the real-time data feed? Are you seeing a problem now? The data feed from our side is working without any problem. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
