Date/Time: Sun, 24 Nov 2024 06:56:31 +0000
Enabling Toolbar in Detached Chart Windows
View Count: 1934
[2013-10-08 18:56:27]
hft168 - Posts: 31
Hi S.C. Support,
I have the level of subscription for detached windows, but get lost on how to enable the same or similar tool bar on the main window within a detached charts.
If in the detached chart window, I go Window-->ToolBars to enable a Toolbars (say Toolbar 2), it adds a second toolbar under the main window, not the detached one.
It would be nice if each detached window can have the same or similar toolbar. Not sure this function is there or not, please advise.
Thank you!
[2013-10-09 03:56:27]
This is not currently supported. However, it is possible to detach a ToolBar from the main window:
http://www.sierrachart.com/index.php?l=doc/doc_WindowMenu.html#ToolBar
