Date/Time: Sun, 19 Jan 2025 18:02:02 +0000
Trade Live With A Sub-Instance?
View Count: 1058
[2018-04-27 01:20:27] |
User240019 - Posts: 112 |
When I look at the data settings for my sub instance, it does not appear to be connected to my broker. Am I missing something?
[2018-04-27 01:45:16] |
Yes the trading does go through the main instance. The sub instance does not directly connect to the trading service.
[2018-04-27 14:43:46] |
I'm confused - so, if I place a live trade on the sub instance, will my broker process it or no?
[2018-04-27 23:23:02] |
Yes. So long as the correct Trade Account is selected and as long as Trade Simulation Mode is disabled in both instances. Refer to: Using DTC Server for Data and Trading in Another Sierra Chart Instance: Using the Correct Trade Account (Rejections Related to Simulation Mode) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
