Date/Time: Sun, 24 Nov 2024 07:02:49 +0000
chart for traveling in airplan w/o internet connection
View Count: 1292
[2013-10-08 16:45:10] |
User35749 - Posts: 32 |
Hi, I am travel often and is there any way that I can open a chart (based on historical data of CL# and has been saved) for review without internet connection during the 12-hour fly? Thanks, Van Chiem |
[2013-10-08 18:21:11] |
Yes. See: https://www.sierrachart.com/index.php?l=doc/LoginInstructions.php#WorkingOffLine Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-10-08 18:21:36
