Date/Time: Wed, 22 Jan 2025 00:04:50 +0000
DOM Graph depth cannot be limited - graph gets swamped out
View Count: 916
[2018-04-26 14:38:38]
User725927 - Posts: 4
I have Global Settings | Chart DOM Settings | Maximum Depth Levels Displayed set to 50. But the Char DOM depth seems to be infinite. So a whopper limit order 300 ticks away swamps out the rest of the DOM Graph and the horizontal bars within 50 ticks of current price (the area I'm interested in) are too small to be of value. See attached.
How can this be fixed?
Thanks.
Version 1736-64 bit. F.US.CLEM18, 128 Volume CQG,
imageDOM Graph depth problem.JPG / V - Attached On 2018-04-26 14:36:35 UTC - Size: 70.87 KB - 346 views
[2018-04-26 21:35:05]
We are working on implementing a new setting to control the maximum number of market depth levels globally. It should be out in a few more days.
[2018-04-26 21:35:06]
[2018-08-23 13:15:45]
It's been 3 months since you said you would fix this issue. When will the maximum number of DOM graph levels be limited? I have ver. 1781.
Thanks.
[2018-08-23 17:08:43]
Yes. Here is the setting:
https://www.sierrachart.com/index.php?page=doc/DataSourceSettings.php#MaximumMarketDepthLevels
