Date/Time: Sun, 19 Jan 2025 17:49:06 +0000
Quote Board rows not deleting or inserting
View Count: 983
[2018-04-26 12:53:52] |
User75002 - Posts: 117 |
Hello, I am having a problem with my quoteboards. When I go to delete or insert a row, it shifts everything around. See screenshots. I am running 1733. I do not recall needing to manipulate my symbols while using 1727, but know it was never an issue before with 1713 or earlier. Thank you. Normal http://www.sierrachart.com/image.php?Image=1524746986236.png After deleting a row from Natural Gas section http://www.sierrachart.com/image.php?Image=1524747123841.png Date Time Of Last Edit: 2018-04-26 13:09:21
[2018-04-26 15:41:42] |
We will look into this issue today and get it resolved. It relates to the fact the Quote Board updating is more efficient now.
[2018-04-29 12:08:42] |
This is now resolved and will be out in the next release in a day or two.
