Date/Time: Sun, 19 Jan 2025 19:37:51 +0000
Volume By Price Study
View Count: 1219
[2018-04-26 11:26:51] |
ElPotifor - Posts: 4 |
Hello!Is it possible to color volume bars(total volume) depending on the ask-bid difference by current price ? Like in Number Bars Study.Pic is attached |
Screen.jpg / V - Attached On 2018-04-26 11:25:49 UTC - Size: 249.8 KB - 421 views |
[2018-04-26 17:54:15] |
Yes, this is supported. Refer to: Volume By Price Study: Bid Volume and Ask Volume Coloring Method Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-05-02 13:32:53] |
I mean TotalVolume colored by Ask-Bid delta. Is it possible to color volume like at the pic?
Date Time Of Last Edit: 2018-05-02 13:34:23
профиль2.PNG / V - Attached On 2018-05-02 13:32:23 UTC - Size: 44.2 KB - 364 views |
[2018-05-02 17:54:09] |
This is supported with that setting (Bid Volume and Ask Volume Coloring Method). It sounds like this is what you want: Dominant Bid or Ask Volume Coloring - Full Bar: With this coloring method, the entire Volume bar is colored a single color that is either the Bid Volume Color or the Ask Volume Color, depending on which volume is greater.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-05-02 17:54:45
