Date/Time: Sun, 19 Jan 2025 17:35:53 +0000
[Programming Help] - New SC installation compile problem
View Count: 1706
[2018-04-25 14:23:03] |
User950746 - Posts: 3 |
new developer... Any attempt to compile causes the following error: c:\sierrachart\acs_source\scstructures.h(6): fatal error C1083: Cannot open include file: 'windows.h': No such file or directory How can I fix this? Thanks. |
[2018-04-25 17:55:05] |
Describe the procedure you are following to perform the build. Are you performing the build from the Analysis >> Build Custom Studies DLL window?
[2018-04-25 20:08:54] |
Yes. First clicked on "Install Compiler" which appeared to complete. Now using Build Custom Studies DLL button. Screen Shot attached |
SC Compile Error.png / V - Attached On 2018-04-25 20:08:17 UTC - Size: 21.48 KB - 310 views |
[2018-04-30 12:26:50] |
Anybody? Still struggling with this. |
[2018-04-30 19:34:29] |
OK, this is an issue we cannot help with other than to recommend to use Remote Build. Why there is a problem with the Visual C++ compiler installation, we do not know. It really does not make sense why that particular error would be occurring. We ran a test on our side and did not encounter it. So it is something about your installation of Visual C++. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
