Date/Time: Wed, 22 Jan 2025 20:48:58 +0000
Activation
View Count: 761
[2018-04-25 10:44:03] |
User873977 - Posts: 2 |
Dear SierraCharts, Do I have to do anything to activate my Trial? Kind Regards, Tamas Kovacs |
[2018-04-25 16:27:09] |
Dear SierraCharts, My Sierra says now that my usage time has ended. Could you activate my trial please? Kind Regards, Tamas Kovacs |
[2018-04-25 18:40:31] |
Sierra Chart - Max - Posts: 5779 |
Your trial account has not been extended. We see that you have previously used Sierra Chart and have had at least 30 days of trial time. You will need to make a payment for usage time. Follow these instructions to add usage time to your Sierra Chart account: 1. Select "Help >> Add Usage Credit" on the Sierra Chart software menu. You can also go to this page in your browser: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation Login with your Sierra Chart Account Name and Password. 2. Choose the particular Service Package that you want to automatically renew. 3. Add sufficient credit to your Services Balance using any of the available payment options: https://www.sierrachart.com/UserControlPanel.php?page=AddAccountCredit For further information, refer to: Sierra Chart Purchase and License Information: Renewing Access Sierra Chart Support |
[2018-10-22 20:28:17] |
User127046 - Posts: 3 |
Hello, Please activate my trial account. Thanks |
[2018-10-23 17:35:00] |
You have already received at least one month of free usage time. Follow these instructions to add usage time to your Sierra Chart account: 1. Select "Help >> Add Usage Credit" on the Sierra Chart software menu. You can also go to this page in your browser: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation Login with your Sierra Chart Account Name and Password. 2. Choose the particular Service Package that you want to automatically renew and press the "Update" button. 3. Add sufficient credit to your Services Balance using any of the available payment options: https://www.sierrachart.com/UserControlPanel.php?page=AddAccountCredit For further information, refer to: Sierra Chart Purchase and License Information: Renewing Access Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-10-23 17:35:17
