Date/Time: Sun, 19 Jan 2025 17:42:04 +0000
Download the analysis data
View Count: 569
[2018-04-24 16:13:15] |
User562242 - Posts: 2 |
Hi I am new in SC, I am using trial at this moment I want to know whether I can export the data in Analysis? THanks |
[2018-04-24 19:59:14] |
Yes you can export data of studies. Refer to: Edit Menu: Edit >> Export Bar and Study Data to Text File Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
