Date/Time: Sun, 19 Jan 2025 17:43:54 +0000
showing the evening sessions only for prior day
View Count: 1157
[2018-04-23 13:05:22] |
dd45 - Posts: 41 |
Is there a way to show the evening session but only for the night prior to the current day's open?
[2018-04-23 18:28:00] |
No, this is not supported other than when using TPO Profile charts.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-04-23 18:28:11
[2018-04-23 18:31:55] |
dd45 - Posts: 41 |
I am sorry, I should have clarified, I am in fact using TPO profiles and would like to only show the most recent overnight activity.
[2018-04-23 19:14:34] |
OK. Then you need to set this TPO Profile Chart study Input to Yes: Time Price Opportunity (TPO) Profile Charts: Exclude Evening Session Profiles Except For Last Day Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-04-23 19:14:43
