Date/Time: Sun, 24 Nov 2024 06:50:51 +0000
Chart Trading/two different versions of Sierra
View Count: 1262
[2013-10-08 12:51:49] |
tdemmon59612 - Posts: 6 |
I have two versions of Sierra Charts. One in which I run a data feed (IQFeed) and the other version came with my broker who is Transact. I would like the ability to trade off the charts of the one with the data feed (knowing that there might be a timing issue in terms of execution. I was told that the two versions could be linked somehow so that the version with my brokerage account could be run simultaneously with the version with a good data feed so that I can trade off the charts with the better data feed. Also, the reason for the two different versions is that Transact data versus the IQFeed is not comparable despite Tranact data being actual trade executions. Can anyone direct me on how to do this. Thank you, Ted |
[2013-10-08 15:39:17] |
This is explained on this page: http://www.sierrachart.com/index.php?l=doc/MultipleServices.html What you can do is use the data from the of copy of Sierra Chart connected to IQ Feed in the copy connected the TransAct for trading. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-10-08 18:50:02] |
I need someone to walk me through it by remoting on to my machine. Although the instructions are somewhat clear...it is simply not working for me. Is there any further assistance I can get?
[2013-10-08 20:36:12] |
Yes. We can help with this. There is a small charge for this service. Please contact us here so we can schedule a time: https://www.sierrachart.com/usercp.php?page=SupportTickets Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
