Date/Time: Sun, 19 Jan 2025 15:01:55 +0000
Trade >> Trading Chart DOM On on the menu needs to be checked. No where to find?
View Count: 619
[2018-04-22 13:34:01] |
Diana - Posts: 42 |
Trade >> Trading Chart DOM On on the menu needs to be checked. When you enable Trading Chart DOM On, the Chart Trade Mode On and Show Orders and Position options will also be enabled automatically. Trading Chart DOM On will display the Buy and Sell order entry columns on the right side of the chart which are used for trade order entry. Refer to the image above. In the case of the Trade DOM, Trading Chart DOM On is enabled and stays on.
360截图20180422213329208.jpg / V - Attached On 2018-04-22 13:33:54 UTC - Size: 48.83 KB - 273 views |
[2018-04-22 13:45:33] |
Xfanman1 - Posts: 320 |
If you’re using Infinity Futures Transact version of SC they do not have the option enabled for some reason. You’ll have to discuss that with them. When I demo’d SC with them last year at least that was the case. — Scott |
[2018-04-22 19:09:32] |
You need a direct account for this functionality: Direct Sierra Chart Account Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
