Date/Time: Sun, 19 Jan 2025 17:55:34 +0000
[User Discussion] - Capturing study data from another chart&&&& RTH auto set?
View Count: 611
[2018-04-22 09:10:52] |
Diana - Posts: 42 |
Capturing study data from another chart -- I have limited experience using this, but SC has built in studies that allow indicator data from one chart to be copied to the current chart. Useful for creating an RTH VWAP on an ETH chart, for example. I've seen this in forum, and don't konw how to do that. 1.For example I have 2 timeframe charts and the same indicator, I want 30mins chart can show the indicator for itself and in daily charts. 2. creating an RTH VWAP on an ETH chart is someting I want to do. 3. BTW, can I set RTH for let's say CL, not specify it just check RTH can it automatically set for me? for I'm in China and RTH changes 2 times a year and I don't want to miss it. |
[2018-04-23 00:39:56] |
Xfanman1 - Posts: 320 |
Study/Price Overlay Study: Using the Study/Price Overlay Study https://www.sierrachart.com/index.php?page=doc/StudyPriceOverlayStudy.php#OverlayStudyDiffSessionTimes This study should do what you want to accomplish I believe. -- Scott Date Time Of Last Edit: 2018-04-23 00:41:00
[2018-04-23 05:48:18] |
Diana - Posts: 42 |
Can I have 2 charts and just copy one chart's study to another one is daily and aother is 30mins and the same study?
[2018-04-24 11:34:34] |
Yes, but depending on what study you're overlaying you'll have timing issues since both charts are displaying different time frames. If all you want to display is a current value from the other chart, it's much easier to do using the Text Display For Study From Chart study. Experiment with it and see what happens. -- Scott |
