Date/Time: Sun, 19 Jan 2025 15:20:38 +0000
combining DOM with Chart, so quick to enter order on chart
View Count: 673
[2018-04-22 07:25:04]
Diana - Posts: 42
1.combining DOM with Chart, so quick to enter order on chart,means ChartDOM -- Sierra has a DOM on the actual chart ,,,, how to do that?
2.can I make the width of the chart order lines variable?
3."Smart scaling -- Sierra has the "constant range autocenter" and other intelligent ways to adjust the scale"-----where?
4.where to set Chart update interval that I can get faster ?
[2018-04-22 19:11:44]
You need a direct account and you have to start paying for further support. Refer to:
Direct Sierra Chart Account
You have gone way too far with all of your questions. You should recognize this and think twice before you post and instead consult the documentation. We are declining further support and locking out access to this Support Board. You will need a direct account going forward.
Date Time Of Last Edit: 2018-04-22 19:20:04
