Date/Time: Sun, 19 Jan 2025 15:17:18 +0000
Can I attach the attached orders BEFOR my order filled?
View Count: 683
[2018-04-21 17:16:58]
Diana - Posts: 42
for sometime I foget to check the "use attached orders".
[2018-04-21 23:11:13]
Yes. Follow the instructions here:
Order Types: Send Attached Orders - Position/Price
[2018-04-22 02:09:18]
Diana - Posts: 42
I've tried that before, it just don't work after my parent filled, but I'm not always beside my PC to let it fill to set the attached. sorry.
image360截图20180422100754269.jpg / V - Attached On 2018-04-22 02:08:10 UTC - Size: 148.24 KB - 289 views
[2018-04-22 02:24:59]
In this case that is because there is no Position. In that case you need to use the method explained here:
Order Types: Sending Attached Orders from the Trade Window
