Date/Time: Sun, 24 Nov 2024 06:22:30 +0000
LMAX and Volume Studies
View Count: 1334
[2013-10-08 09:47:13] |
User85153 - Posts: 7 |
To what extent are volume studies support with the LMAX feed? In particular numbers bars and T&S - are the volume of contracts transacted accurately reflected - it appears that all T&S records are showing a volume of 1 per transaction which suggests Sierra isn't recording the volume date but just price at which transactions were carried out? |
[2013-10-08 15:31:17] |
LMAX does not provide volume data. A volume of 1 means one price update.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-10-08 15:31:46
