Date/Time: Sun, 19 Jan 2025 15:08:22 +0000
VbP Study - Lines only mode - Extend Point of Control
View Count: 586
[2018-04-21 08:49:13] |
User353585 - Posts: 66 |
If I set VbP study to Lines only mode, extending the point of control option won't work any more. (or any other extending options) I don't know if this is intended or something you can fix. please let me know, thank you. |
[2018-04-22 19:04:18] |
Yes this is true. It is not something we would change.
