Date/Time: Sun, 19 Jan 2025 15:02:39 +0000
Executing hidden orders through Interactive Brokers
View Count: 1330
[2018-04-20 19:14:47] |
User350035 - Posts: 1 |
Dear Support, Could you please explain how I can use the feature of hidden orders within Interactive Brokers on the Sierra charts/dom platform? According to Interactive Brokers: Investors wishing to hide large-size orders can do use by applying the "Hidden" attribute to a large volume order to completely hide the submitted quantity from the market. The Hidden order type is a simple solution to maintaining anonymity in the market when trying to buy or sell large amounts of stocks, options, bonds, CFDs, warrants, futures or futures options. The Hidden order type is simple to add to the main trading window within TWS and requires a simple check-mark in the box in order to activate. Display the Hidden field from the Layout Manager, and check the Hidden attribute in the order line. Your order is submitted but evidence of the order is hidden from the market. Thank you for your time. Sincerely, |
[2018-04-20 22:27:42] |
In Global Settings >> Data/Trade Service Settings >> Service Setting you need to set this setting to True: Submit Orders as Hidden Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
