Date/Time: Sun, 19 Jan 2025 15:16:55 +0000
Skipping
View Count: 551
[2018-04-20 16:19:25] |
User324244 - Posts: 1 |
Hi, just yesterday my software started skipping in 1 second intervals. My data no longer flows thru quickly - it just updates every 1 second and appears just super sluggish. Haven't encountered this before and I'm curious if this might have something to do with the update? It's relatively unuseable in this state unfortunately for my purposes. Thank you
[2018-04-20 19:03:37] |
Refer to this help topic: http://www.sierrachart.com/index.php?page=doc/helpdetails4.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
