Date/Time: Sun, 19 Jan 2025 17:54:21 +0000
Cancel Outstanding orders when flat a position
View Count: 2491
[2018-04-20 13:34:07]
John R D - Posts: 25
I'm looking for a feature that will cancel all my outstanding orders for a position when Im flat.
For example Long a position have a limit order higher to sell and a stop order lower to sell. The limit
order fills now flat the position. Would like the stop order to cancel as soon as the limit is filled.
John
[2018-04-20 18:38:01]
For this you need to use Attached Orders:
Attached Orders
[2018-04-20 19:46:04]
Hi, I'm not looking to use OCO or Bracket orders. I place orders on the Dom with hot keys
or a mouse click. I found this post that addresses exactly what I would like to accomplish. The post
explained that there was a solution but the outcome is unknown based on this post. See post below.
Order handling/cancel all
John
[2018-04-20 23:57:22]
Yes that feature is available on the Trade Window Menu. Refer to:
Basic Trading and the Trade Window: Main/C >> Menu >> Orders >> Cancel Orders on Flat Position (chart specific)
Date Time Of Last Edit: 2018-04-20 23:57:29
[2018-04-23 13:15:20]
Ok thanks. Is this what your referring too. Flattening All Non simulated Positions and Canceling All
Orders in a Single Operation.
https://www.screencast.com/t/oNYsPCG84
[2018-04-23 18:03:06]
We are referring to this option on the Trade Window menu:
