Date/Time: Sun, 19 Jan 2025 15:28:20 +0000
Concatenation of alerts
View Count: 639
[2018-04-20 12:19:20] |
User470516 - Posts: 78 |
Good morning, I am struggling sending out two alerts one after another during the same bar, so as to "concatenate" them. The documentation stipulates : "During a call into a study function, if there are multiple calls to sc.SetAlert() at the same or different bar indexes, only one will actually generate an alert. The rest will be ignored." I am trying to achieve the following: play alert "BUY DAX" and immediately after play alert "Bar period 60 Minutes". I am right if I say this not possible within ACSIL? Could it be possible in the future? For instance if the fucntion could do: sc.alert(int NumberOfAlerts, int AlertNumber#1, int AlertNumber#2, int AlertNumber#3,..., int Index, SCString Message); Thank you for your support. Regards, Laurent |
[2018-04-20 19:13:12] |
You need to use this particular function: sc.AlertWithMessage Refer to: sc.PlaySound() Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
