Date/Time: Mon, 03 Feb 2025 13:09:53 +0000
[Programming Help] - Customizing the menu in the latest version (1733)
View Count: 1685
[2018-04-20 07:33:29] |
2garin - Posts: 184 |
In the latest version, the menu (Russian language) is no longer displayed. The download link does not work. Check, please.
[2018-04-20 08:12:41] |
We will look into this. We have been doing some work to support 16-bit characters in Sierra Chart and the menus. Specifically what do you mean by this: The download link does not work. What download link are you referring to? We are not seeing a problem with the link here:Software Download: Software Download For now go back to a prior version: Software Download: Software Rollback Procedure Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-04-20 08:13:27
[2018-04-20 08:28:50] |
https://www.sierrachart.com/AdditionalFiles/Translations/RU/MenuCustomizations.xml
Date Time Of Last Edit: 2018-04-20 08:36:17
[2018-04-20 09:30:09] |
ganz - Posts: 1048 |
User62522 на ссылке правой кнопкой мыши -> сохранить ссылку как ... (этот коммент от пользователя) Date Time Of Last Edit: 2018-04-20 09:31:18
[2018-04-20 09:49:52] |
file uploaded (MenuCustomizations.xml), copied to the folder (C:\SierraChart), the problem remained.
[2018-04-22 23:02:19] |
We made a change in 1735 which should resolve the issue. Update following these instructions to the latest Prerelease: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-04-27 01:51:27] |
We realize that the reason for the problem was more involved. The issue is definitively solved in the latest revision of version 1738. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-04-28 03:06:05] |
the localization file came up perfectly. when trying to dopill the menu for myself in the menu localizer I see unreadable characters. why? |
[2018-05-01 21:23:11] |
We apologize for the delay with this. This problem will be resolved with a new release coming out today.
[2018-05-12 01:49:27] |
Iinstalled version 1744. The menu localization file was downloaded again and placed in the program directory. Why does not localization work?
Date Time Of Last Edit: 2018-05-12 01:53:58
[2018-05-14 18:27:18] |
Attach here the MenuCustomizations.XML file you are using and we will test it.
[2018-05-18 10:15:21] |
Additional Language Support https://www.sierrachart.com/AdditionalFiles/Translations/RU/MenuCustomizations.xml Date Time Of Last Edit: 2018-05-18 11:03:51
MenuCustomizations.xml - Attached On 2018-05-18 10:15:04 UTC - Size: 39.34 KB - 408 views |
[2018-05-18 19:32:53] |
We mistakenly had support enabled for Unicode characters which does not work correctly at this time. The character encoding that menu customization file uses is not Unicode. We are putting out a new revision to solve this.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-05-18 19:36:35
[2018-05-18 19:36:01] |
We have released a new revision of 1748. Update with Help >> Download Prerelease.
[2018-05-19 16:49:11] |
The menu is displayed in Russian. The menu editor was left with problems. What happened to the menu buttons?
Date Time Of Last Edit: 2018-05-19 16:50:15
[2018-05-22 04:24:04] |
We looked into this, and we determined that this has always been the case. When working with characters that are non-ASCII you really have to do the customizations through the XML file directly. When Sierra Chart has global Unicode support, this will be solved. In regards to the Control Bar buttons, there must be one button with text that is very wide. You can solve this by disabling the option which is documented here: http://www.sierrachart.com/index.php?page=doc/ControlBar.php#UseSameSizeForControlBarButtons Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-11-17 12:02:01] |
How long can I expect Unicode support for _Sierra_Chart ? How to configure a keyboard shortcut without deleting the Russian language localization file? How long to wait? |
[2019-11-18 18:12:27] |
We are working on this now and we hope to have this out in about four months from now. How to configure a keyboard shortcut without deleting the Russian language localization file? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-11-18 21:17:23] |
How many years to wait for proper Unicode support?
