Date/Time: Sun, 19 Jan 2025 15:27:06 +0000
I'd like to know what connection service do I have with Sierra Chart? and how to set up an
View Count: 656
[2018-04-19 22:32:47] |
User123003 - Posts: 29 |
I'd like to know what connection service do I have with Sierra Chart? and how to set up and connect them. Thank you, |
[2018-04-19 23:00:54] |
There are many supported Data and Trading services. Currently we see you are using TD Ameritrade. Do you have a TD Ameritrade account? What markets do you need data for or want to trade? For example, what particular futures, Forex or stock symbols. You can also give us the exchanges that the particular symbol or symbols trade on. If you require real-time futures data, then refer to: https://www.sierrachart.com/index.php?page=doc/doc_FuturesData.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-04-19 23:17:26] |
I have a TDAmeritrade account, and I'm currently using them. My question was when I paid this $24 to SC, does it including data service that Sierra Chart provide? Such as CTS? How to set up 5 symbols in one chart, I mean adding more symbols to one chart not study. Thank you, |
[2018-04-20 00:52:47] |
There is some data services included in the 24 USD: Description of Service Packages and Pricing: Included Data and Simulated Trading Services However, we need to understand what you specifically require. This is the only way we can properly answer the question. Refer to our post #2 above. CTS is an external trading platform service with its own fees. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-04-20 00:55:15] |
How to set up 5 symbols in one chart, I mean adding more symbols to one chart not study. https://www.sierrachart.com//index.php?page=doc/StudiesReference.php&ID=400&Name=Add_Additional_Symbol Although it is a study, it just adds additional symbols into the chart. And refer to our post above for the other answers. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-04-20 04:51:12
