Date/Time: Sun, 19 Jan 2025 15:14:54 +0000
Open Orders canceled by time
View Count: 805
[2018-04-19 18:57:10] |
GreyLock58 - Posts: 170 |
Is it possible to cancel open orders by a preset time through SC? I see the option for "Good till Cancelled", "Good till Date Time" and "Day", but I want to cancel open orders at a certain time. Is this possible?
[2018-04-19 19:15:09] |
Not exactly but we can add this. There is now the capability to flatten the position and cancel orders for the Symbol and Trade Account of the chart at a set time and that does exist in the latest release on the on A tab of the Trade Window: Basic Trading and the Trade Window: Opening Trade Window for Chart or Trade DOM Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-04-19 19:15:24
[2018-04-19 19:32:07] |
Yes, I use the "Flatten Positions at Set Time" within "Global Profit/Loss Management" and it works great. But I would like the same option for cancelling Open Orders at set time. If you can add this it would be appreciated.
[2018-04-20 19:49:06] |
You state that you can add this feature. Could you give an approximate time frame.
[2018-04-20 23:54:25] |
This is now available in 1734 on the A tab of the Trade Window.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-04-20 23:54:48
