Date/Time: Sun, 19 Jan 2025 15:09:59 +0000
Can SC add the execlnst settings for the DTC integration method?
View Count: 676
[2018-04-19 18:09:09] |
User960746 - Posts: 25 |
1. I am trading with several Bitmex accounts, because the new direct BitMEX trading integration does not support multiple accounts trading, It is only supported with the DTC integration method. Please add the four additional setting options for the DTC integration in the Data/Trading Service Settings as the new Direct BitMEX trading integration has. 2. What's the advantage of the new integration compared to the DTC integration? 3. For the new BitMEX Trading Direct Integration, in the Data /Trade Service Settings, what's the difference between 'Addtional execlnst for Stop Orders with Index Price' and 'Stop Order Price Reference with Index Price'? 4. When trading with multiple accounts, is it possible to place orders or modify the existing order price for all accounts simultaneously with one click? And for different account, when placing the orders, is it possible to auto calculate the order quantity based on the account balance and a given percent rate. Is the solution to this issue to by developing my Advanced Custom Study? If so, can the advanced custom study fulfill all my function needs? Can SC consider to add multiple accounts trading function with one click, and x percent order quantity auto calculation based on the account balance? It's really helpful and convenient. 5.Can SC consider to add the function for adjusting the leverage rate in Bitmex? Thank you so much and Have a good day. |
[2018-04-19 19:21:02] |
1. This is very impractical. It is not something that would ever happen. 2. This is explained here: Direct BitMEX Trading Support 3. There should be no difference. 4. Answers an order of questions: No. No. Technically but this is well outside the scope of our support to provide any help with. Same answer as previous. Not at this time. 5. No, this will never happen. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
