Date/Time: Sun, 19 Jan 2025 15:12:36 +0000
chart trade mode off?
View Count: 1149
[2018-04-19 13:12:45]
Diana - Posts: 42
sometime I want to look clearly and hide chart trading, what's happening about my target-stop attached orders?
[2018-04-19 19:31:19]
Refer to:
Trade Menu: Chart Trade Mode On (Trade menu)
[2018-04-21 06:56:42]
Diana - Posts: 42
“If you want to just display orders on the chart but not be able to modify or cancel them, then disable Trade >> Chart Trade Mode On and instead enable Trade >> Show Orders and Position .Control Bar buttons can be set up for each of these commands.”
1. So means once I place it ,I can disable it and it can still work for mother order and attached orders?
2. I can not techinically hide them.
Am I right?
[2018-04-21 06:58:07]
Diana - Posts: 42
3. I disable it and hide the order, then the 3 orders simply doesn't work?
[2018-04-22 00:50:04]
1. Yes.
2. The orders do need to be visible for them to fill if they are simulated orders.
3. Only if the orders are simulated and this is explained here:
Trade Menu: Show Orders And Position (Trade menu)
Otherwise, they will be still fully functional even if not displayed on the chart.
4. You also have the ability to hide the Attached Orders only:
Basic Trading and the Trade Window: Main/C >> Menu >> Settings >> Hide Pending Attached Orders (chart specific)
Date Time Of Last Edit: 2018-04-22 00:58:43
