Date/Time: Sun, 19 Jan 2025 15:14:17 +0000
Volume At Price Threshold Alert V2 - Volume Threshold
View Count: 879
[2018-04-19 02:26:41] |
User852663 - Posts: 21 |
I noticed that if the comparison method is "Ask Volume Bid Volume Diagonal Ratio" then neither the "Volume Threshold" setting on ln2 or the "Additional Volume Threshold" setting on ln7 are used. Can there be a volume threshold setting used for that comparison method? It's my understanding from the documentation that this comparison method is most similar to what you would get with the Number Bars study comparison which I am using for something but I need to be able to have the volume threshold. EDIT: I just looked and saw that you include the source code for that study. I don't see anything doing a check on volume threshold in index 7 calc method which I was able to fix and compile into a new study for myself. It also appears this source code is different than the current study because I don't see ln8 and ln9 settings in the source code that I see in the study (About zero value compares.) Date Time Of Last Edit: 2018-04-19 04:24:09
[2018-04-19 19:27:48] |
Yes we were going to recommend to modify the source code for that study to meet your requirements and build a new study. The source code provided for a study with each version of Sierra Chart has to match the same study in the program. There are no differences. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-04-19 20:11:08
[2018-04-19 20:04:23] |
My apologies. I was looking at the source code in a different folder where an older version of the software was so that must have been a prior version without those settings. All set now. Thanks very much for your help.
