Date/Time: Sun, 19 Jan 2025 15:26:27 +0000
set mouse up to scale big?
View Count: 694
[2018-04-19 00:33:40] |
Diana - Posts: 42 |
Can I set mouse up to scale big instead of scale small?
360截图20180419083259280.jpg / V - Attached On 2018-04-19 00:33:31 UTC - Size: 96.54 KB - 285 views |
[2018-04-19 19:48:17] |
We do not understand the question.
[2018-04-21 08:20:40] |
Diana - Posts: 42 |
Can I set mouse up to scale big instead of scale small? mean you drag the mouse in Y, down is bigger and I want up is bigger for price scale. |
