Date/Time: Sun, 19 Jan 2025 15:03:58 +0000
Daily OHLC calculate session break rather than the ordinary day?
View Count: 728
[2018-04-18 16:57:26]
Diana - Posts: 42
can Daily OHLC calculate session break rather than the ordinary day?
means the trading hour from 18:00pm-17:00pm.
image360截图20180419005648001.jpg / V - Attached On 2018-04-18 16:57:19 UTC - Size: 88.53 KB - 291 views
[2018-04-18 18:51:44]
The study does not have the ability to use a different set of hours than what is set in the Chart >> Chart Settings >> Session Times. You would need to set the Chart Session Times to 18:00 - 17:00 in order to have this show the way you want.
The documentation on the Chart Session Times can be found here:
Chart Session Times
This is fully explained with the study here:
Daily OHLC
